Onstar App Update, They Finally Added Something Useful
OnStar App had an update last night on my ipad and Android phone.
They added GPS routing to it, using Google Maps thru the App you can enter an address, or search for a POI, then send the address/destination directly to the GPS in your vehicle (must have onstar directions and connections service).
using the voice command on my Android phone I was able to speak the name of the Restaurant I wanted, google maps located it, and I clicked the link to "send to GPS" (you can also send to the OnStar turn by turn if you don't have GPS but have OnStar Turn-by-Turn service)..
downloaded to my GPS in the time I sat at a red light..
up to now I didn't find much use for the app, I have remote start on my key fob and I can read my TPMS and Gas Gauge in the Truck.
This however makes the app worth something to me, now if they would just add a "locate your vehicle" using the GPS so if someone steals it you can track it, and maybe the features they use to reduce power and flash the lights.. Then they would have a completely kick ass app and justification (for me) to maintain the service after my free trial is over.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
