tire recommendation
Hey guys
I'm in need of new tires to replace my BFG Long Trails. I've had nothing but problems with these for the last 6 months. I bought them from Sam's club and have already replaced two fronts for new ones (they wouldn't give me 4 :puke:  ).
I've never had problems before with the BFG's, but these are way too noisy. My mechanic told me it is because it is the way they stack them and it warps the belts...
Anywho, I'm replacing them and want to go elsewhere this time (Sam's has their own "brand" made for them, like Sears)
Michelin's are too expensive, so I'm not going that route. Suggestions?
Thanks
Had the stock Firestone 265/75/16 on my 99 Rado z71 replaced with Bridgestone Dueler AT Revos at 39k.  The wet traction is excellent compared to the f-stones.  Took a trip to Kentucky a few weeks back from Cleveland and they rode smooth and quiet.  Thumbs up so far.
I have Cooper Discoverer A/T's right now and they are GREAT so far. Seems like they stick better on wet roads :puke: . I am just hopin they'll last half as long as Michelins because they are half the price.
I've run 305/70R16 Goodyear AT/S and they are a good tire
I currently have a set of 285/75R16's and I love them...they are kinda loud but they have enough nobby to get you into and more importantly out of mud and do a little singing on the road...
The Suburban I just got for my wife has a new set of Toyo Open Country AT's on it and they look really sharp.  No idea of price, but I noticed in the new Truck Trend they put a set on their project Tacoma.  I've only driven them in snow so far, but so far so good -
I'm going to go for a set of the 285/75R/16 BFG AT's after the holidays.  I've heard nothing but good things about them.  But that's just me....
Definitely stay away from the :puke: Fire/Bridgestones.  I couldn't stant the stock ones that came with the truck.....lousy excuse for a tire!
Thanks for the replies. Looks like the new tires are on hold and the money is going to brakes instead  :puke: . One of my pads seems like it broke out from the caliper... if it isn't one thing, it's another  :puke:
I also have the 285 Coopers and I think they're great. Only about 2,000 mi. They're also very good in the snow, and if price is an object, they can't be beat. :puke:
www.nokiantire.com - I just picked a set up for the Trailblazer.  I got the WR model for $99.50 each.  They appear to be a really nice tire.  Basically a snow tire that is rated for all year use with excellent wet weather traction.  I think I might try their truck tire next time I need them.  I haven't been satisfied with any tire in my whole life, but these look promising so far.
The BFG At's are a good pick.  I've had them on 3 trucks and they worked great.  Got about 10k on my 285's with minimal wear, little road noise and good on and offroad traction.
I have replaced the tires on my last three vehicles with Cooper Discoverer's. The last set were ATs. They are great in snow. I plan on getting some when my Firestone's wear out.
Bob G.
If you want a smooth quiet ride... the only way to go is Michelin.
I just put their Cross Terrain SUV tires on my '00 Silverado and love 'em.
Of course you sound more like you want A/T tires... so these may not be the best for you, although their wet traction so far is easily 5 times that of the crappy goodyears my truck came with from the factory.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
