2001 Yukon Electrical Probs
My wife has a 2001 Yukon which is having some electrical problems. The left rear door window & power lock does not work properly, keyless entry does not work, & last week the power mirrors stopped working.
I have checked all fuses, switched door lock relay, and checked power at each item in the door. The door lock actuator seemed low with 6 volts, the window motor had 12 volts. I am curious to see if I should replace the actuator or if the BCM may be causing some of the problems.
Any help would be greatly appreciated.
Thank you in advance,
TJ
