Intro
Patch6713
Hello everyone. Just joined this forum about an hour ago, after searching around the website for a few hours absorbing as much information as I can. I have a 2005 GMC 2500HD. I haven't really done any modifications to it, but after reading on this sight I have definatly gotten a few ideas. I can't wait to read some more on here and maybe even be of some help for some people.
