Exhaust Tip
i have a 22in magnaflow single in single out in place of my stock muffler, i kept the stock piping, and i want to add a classy, and clean tip that fits well. any recommendations? nothing that hangs out past the body like iv seen people with
I don't know what the diameter of your stock exhaust is but I put the 3.5in to 4.5out from summit on my truck and love the way it looks.
those all look pretty good, should i get a weld on or get one that bolts on? and i really like the 22in magnaflow, its not obnoxious, its just the right sound, doesn't drone, i would def recommend
Mine's a weld-on that I drilled and tapped and bolted to the tail pipe. Didn't want any noise from vibration.
mine are bolt on that have been welded in place. Your good either way really. I like the bolt on because I positioned it exactly where I wanted it and then had a shop weld it.
so what i need to do is cut off where i want the tip to go and then bolt it on, or have it welded on? i really like that double tip above, but cant decide if its to much to me
