Trans Question
So I am stumped now, and I could use a little help answering this one. I have a 2010 4.8L 2wd with the 4 spd. My question is this. I was on the Blackbear website and sent them a message about some questions I had about their tunes. I said that I would like to get a new set of computers (PCM-TCM) to swap out for my factory ones when I go to the dealership. I got a reply from them saying that I cant swap the TCM because its inside the trans. I thought that was only true on the 6 speeds? Any info you can give me on this would be great. Im sure someone on here can answer this. I just dont want to keep emailing the guys over at blackbear if I can have someone on here help me out.
