Tire Size Options 20"
07cliffordreddog
Hi Gang,
My factory goodyears will not make it through another winter. I started researching the factory 265/60 20 size- I was simply in awe that there is only one tire made in that size, the factory goodyear wrangler that came on the truck!
So my question is, Have any of you replaced your 2500 factory 20" tires yet? What tire did you choose? and in what size?
I want something that will fit without any rubbing issues to worry about. I have always bought BFG All-Terrains for winter, but not sure if the 20" sizes that they offer will fit properly.
Thanks for the help!
PS- I know everyone loves pictures, so theres one of my truck!
