Stereo Doesn't Turn Off
I have an aftermarket stereo with amplifier and subwoofer in my 2006 GMC Sierra 1500 SLE Crew Cab. (Stereo is a Pioneer DEH-P710BT) It has always worked fine up until a few days ago when I was testing a friends amplifier before we installed it in his vehicle. The power cable accidentally touched the ground cable and blew the fuse. The ground cable is attached to a bolt on the back seat. I am not sure if this was the cause for the problem but I thought I might mention it. For some reason the stereo will not turn off anymore, even when I open the doors. The dash also still displays when the door is open. I have also noticed that I nolonger hear the door chimes and OnStar doesn't seem to work either. Does anybody have any idea what might be causing this to happen?
Check all grounds, and all fuses stereo and truck wise, after that unhook the battery for awhile so everything can reset, this might fix your problem if not will have to dig a little deeper on what happened.
I'm guessing you have an adapter for your aftermarket headunit since you still have Onstar and retained power. If so, it has likely failed and is the cause of your problems.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
