Was Looking At Different Oils And No Dexos?
I was at walmart yesterday looking at the different oils to see if they had the Dexos emblem on them and they didn't. I looked at Mobile 1, Penzzoil Platinum and neither had the Dexos symbol on them. Have they not started putting this on them even though the Dexos website says both these brands are approved? I was hoping to go with Penzzoil platinum. I know M1 is known to be good but I've used it several times on past cars and it always seems to evaporate some whether the Mobile products were synthetic or not, as soon as I changed brands the dipstick wouldn't go down in 6000 miles when the Mobile 1 would. Thanks...
I take it from the lack of response that the Dexos label hasn't made it to oil containers at local stores. A friend was telling me that my local dealer only charges $30-$40 for oil changes, that's an idea and will put my concerns to rest; although I have trust issues with other folks touching my truck. What if they don't tighten the plug, or filter hmmmm what to do.....
Your local Walmart, apparently, still is into old inventory of motor oil or does not rotate stock when restocking shelves. Most areas now have the Dexos 1 logo on the bottles. To meet the Dexos 1 standard, the oil will have to be at least a semi-synthetic.
O'Riley's ran a special, a few months back, on Penz Platinum for buy 1 quart, get one quart free for up to 6 quarts. One 6 pack I bought didn't have the Dexos symbol, one did. Either way, I have a receipt for a Dexos approved oil being bought for my truck so I'm not loosing sleep over it.
What if the bulk drum of oil at the dealer DOESN'T HAVE THE DEXOS EMBLEM ON IT?! HOW WILL YOU LIVE WITH YOURSELF? :lol:
Buy the PP, put it in your truck, install a quality filter and move on.
Apparently your forum name is appropriate. :lol:
Thanks guys. It makes sense because my local walmart is a very busy store but poorly stocked across the board. Usually when I hit a walmart in a nearby town the stock is so much better. I see things not typically offered at my crappy wally world. :lol:
I've noticed that they might not have the emblem on them but have it written on the back. This just means they meet the standard and are not licensed to put the trade mark on the bottle because they didn't pay GM to be certified.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,180 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
