Double Din W/bluetooth Quality
I am considering replacing the stock Bose headunit in my 06 Silverado with one that has handsfree bluetooth calling capability. I also want to be able to use the song library from an iphone.
Is there a difference in call quality between manufacturers/price points with the different units? (I am assuming there is)
I don't want to bother if the sound quality for me or the other end of the call is going to suck. Right now, I haven't found a bluetooth earpiece that doesn't offend the other caller while I'm driving. My truck isn't loud, but it is a little more agressive than stock (Silverline 4" turbo back with muffler). I think it is more road noise than anything else, exhaust noise is only an issue when I jump on it.
I don't need nav or DVD.
  • 3 weeks later...
I just installed a Clarion CX501. Bluetooth telephone and A2DP streaming audio. No DVD, no touchscreen, just a great (and inexpensive) interface. Easy to operate day or night.
In my experience with Bluetooth head units, it is best to stay away with the ones that say "built in bluetooth" I would go with the models that have an add on bluetooth interface with a wired mic. For instance the Kenwood DVD players require the KCA-BT300. In my experience these give you much better call clarity and reduce background noise for those that you are talking to.
Also, devices such as Parrot are really good but do not integrate well with your aftermarket head unit.
One of the things that appealed to me about the OGM-1 was that the bluetooth module is built in BUT it is made by Parrot. Kudos to advent for not thinking they could do as good a job as a company that specializes in it. BT is very touchy and you really have to know what you are doing and not just "wing it". Having my contacts sync automatically is also a really nice feature which, again, parrot has been doing for years and has it down.
It works well although I am having trouble with dropped connection with my new Android phone but I think it is the phone to blame here since my previous phone never gave me any trouble.
Ernie
I've had the best luck with Pioneer and Kenwood ... I am running Kenwood now ... absolutely no complaints ...
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
