Spring Swap
2000 Silverado: Does anyone know if the rear leaf pack from a 2500 will physically fit a 1500 and how much higher the truck would sit? I wanted to add a lift kit but i,d like to increase the rate as well...Thanks
Yes they should bolt right in. I did that on my last truck. The 3/4 ton springs are as tall as your 1/2 tons with the spacer block, so if you leave the block in and add the 3/4 ton springs you will gain the height of the block. I was thinking about 2 inches.
Ah..ok...I would be correct in assuming the 2500 does NOT use the spacer block?
    liddlera
    liddlera
  • Who's Online   3 Members, 0 Anonymous, 640 Guests (See full list)
