2011 Sierra Black Bear TUNED!!!
I just got my 2011 4.8 sierra black bear tuned! I had a hell-of-a-time figuring out the AutoCal. Justin and Jenna make a GREAT team for customer service. I spent the majority of the day playing email tag, but in the end it worked out awesome!!
Im still not 100% on the capabilities of the AutoCal. Meaning I dont really know what I could change if I wanted to.
Im using the 87 octane engine tune
As for MPG gains.... give me a little while to find that out :driving: because im telling you what when you put the sport tune on (when i push tow haul button) and the truck shifts from 1st-2nd, it brings a smile to my face! its awesome!
you can feel the truck pulling ATLEAST 10-15% harder from 3K- redline. throttle response is greatly improved. the bottom end of the 4.8 is kind of gutless to begin with, but this tune helps.
if gas prices werent so high i would fill her up with premium and let her sing with a higher octane tune.
I can feel the difference when its not on sport mode as well, the shifting is less aggressive but the throttle response is much better over stock. however once you pick up the RPM's it just keeps wanting to pull. ITS AWESOME!!!
all in all, im 100% happy with BBP!!! highly recommended
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
