Stock 5.3, where are your shift points?
I'm messing around in HP Tuners and looking at the stock shift points, they're pretty low. You guys with stockish 5.3s, where are your shift points? Any of you BB tuned guys know where your shift points are? Anyone have a dyno graph of a stock 5.3 to see where the HP peak is?
what year is your truck and what tranny do you have? when i put my tune into my truck we left the tranny shift points alone. it works well enough around town for my liking and thats with a 6 speed.
2011, 6L80E.
It looks like this engine peaks around 5200 rpm. That's low! Especially with the 243 heads. I can't imagine how much a cam and intake wakes these things up.
2011, 6L80E.
That depends on what you use the vehicle for. If you want to drag race your "TRUCK", the peak is low. If you want to work your "TRUCK", like in towing and hauling, that peak is a little high........ Sorta looks to me that the design was a compromise to satisfy the broader market.
I use my truck exclusively for towing and have never engaged in a drag race with it. I would love to have the torque peak @ ~ 2800RPM.
2011, 6L80E.
You must want either forced induction or very low horsepower then. Having a torque peak that low (naturally aspirated) would require a cam that would run out of steam very fast on the top end. I mean, even the 8.1L had a torque peak a little over 3k and that had peak horsepower at barely over 4k. There is a reason that engine only made 20-30 more horsepower than the current 5.3L.
Not sure how you figure that. RPM (by itself) doesn't necessarily relate to max HP. I know of engines that achieve 10K HP @ 500RPM (not automotive engines of course).
It's easy to come up with a cam and valve configuration that will give peak torque at 2800RPM and maintain that torque through most of the maximum RPM of the engine. The maximum torque would be slightly lower than an engine that achieves max at a higher RPM. Although when towing or carrying a heavy load, achieving max torque at a lower RPM allows the ability to keep an engine at a lower RPM for longer periods of time while achieving more pulling power at that lower RPM.
There's nothing worse than having to drop the trans into a lower gear in order to achieve 4000-4500RPM to have enough torque to climb a steep grade. The engine would not be able to stay at that RPM (comfortably) for a long period of time (at least not in my truck). If the same rig were able to achieve max torque @ 2800RPM the same rig might be able to climb the same grade @ a higher speed @ a lower RPM in a higher gear and maintain that RPM for a longer period of time (more comfortably).
It is relatively easy to come up with the proper cam to have a peak torque around 2800 rpm, but relatively difficult to have that same cam make good torque out past 5000 RPM without VVT(really needs to be VVT for intake and exhaust separately to be really effective, although cam advance and retard helps some) or forced induction. The closest modern day engine to what you are asking for is the Ford 4.6 and 5.4 modular truck motors. They had peak torques which were low in the RPM band (2650), but were dogs because they ran out of steam at 5k. I really don't think that the Vortec engines and transmissions are ideal for towing either, but they are certainly adequate for the person who tows 3-5k a few times a year (which I would say is more than what the average truck owner does) while still providing a quick and fuel efficient engine for those who "drag race" back and forth to work with an empty truck.
The Gen IV 5.3 is @ ~90% of peak torque at ~2000 rpm. How much better can it get from a naturally aspirated gas motor?
    • Idler Pulley… from what I understand GM and Chevy trucks no longer have an idler pulley.. they stretch belts for both belts… I had mine replaced by my local mechanic last year on my Chevy Silverado 5.3 z71 LT.   They have discontinued using them on 2019 through 2026 as of a Google search.
    • Good morning! I have a whirring sound coming from the engine or transmission area when driving w/o towing when I accelerate at 1100 rpm’s. That’s how it started. Yesterday it was more obvious while towing a U-Haul even when not accelerating at 70 mph. I could see where it may have been possibly shifting gears due to a slight grade and the intermittent rpm changes as the transmission was possibly lowering the gear down. It was making the sound multiple times but it is not constant. I replaced the serpentine belt and idler pulley but no change. It only does it when I’m driving. No noise accelerating while in park. Just started @ 53,000 miles. It’s not always there though. Unfortunately, I feel it may be transmission related. Any thoughts or knowledge about the 2022 tranny that anyone can share. I have 2500 miles left on my p-train warranty. Thanks to all for any help!
    • RAIN. It's dumping buckets. We needed it. What a welcome change...sitting here listening to it pour with my office window open.   Ok, not too much. It's not even September yet, we're not finished with summer yet....
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
