Wiring diagram needed
I just received a pager alarm (Page Guard).  It came with a wiring diagram for the units, but need one for my 2002
chevy, 2500HD so I can integrate the pager alarm with the chevy alarm.  I know the dealers have access to online manuals
etc., but don't know if earth people do.  Does anyone know where I can get a copy of the chevy alarm system wiring
diagram?
Thanks a bunch.
MR
AZ, looks like what I need.  Do you suppose you could send me higher res. jpgs?  Those are so small my old eyes cannot make out anything but the lines.
Thanks,
MR
