Dyno Tune?
Is $550 to much for a tune on a dyno? I have a local shop here quoted me that price. They use HPtuners software and I would have to bring it back to him to get it flashed back to stock if I have warranty service. He say that there would be no charge to that or if any maybe $10 :dunno: . The dyno is a Mustang brand 1100SE, Eddy Current machine. Now is he able to tune the trans also with HPT and the dyno?
Now BB has the autocal which I wouldn't have to go anywhere to get it back to stock, but would I gain better gain from the local guy?
Depends on how skilled he is at tuning, bb is excellent for myself and many others here, when I got my new pcm I dynoed it and seen the definate hp and tq gains etc, justin also let's you log a few files after the new tune so he can fine tune the truck. Either way, it was cheaper for me to get bb than local. And you can keep your old pcm for 100 extra bucks. Maybe cost you around 350. Just email justin or jenna, jenna is usually on the forum here
I don't think $550 is a good price. I think it's a little high. You can achieve almost the same thing with some data logging but you won't get that fancy print out that says how much HP you got. I believe that you'll yeild about the same performance either way. Plus if you go with the autocal, you can load your stock tune for free :thumbs:
In my opinion, I'd go with BB :thumbs:
My thinking also! Maybe $400-$450 woulda been a better price.
The Mustang Dyno is a good tuning dyno, however, it will all come down to the tuner.
How long will the tuner spend with you? We charge $450 for a dyno tune and Justin spends 2-3hrs with the customer. We also do a street tune/check after the dyno tune, to make sure that it drives the way the customer wants it to. I would definitely recommend doing a street check after any dyno tune- cars perform differently on the dyno and on the road.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
