Whew!!!
Elwood
I just finished a 30 page paper on the history of Europe, and I'm about to finish a 15 page journal for my Special Methods of Teaching Social Studies class.
After this I'll only have a lab test and three finals, then I'm done.
Lab test in the morning
Special Methods final Friday 2:15p.m.
Physical Science final Monday 8:00a.m.
History final Tuesday at 2:15p.m.
I can't wait until break.   :D
Good luck.  I had my design review yesterday (hr long presentation with the faculty) and my machine design final.
1 down 3 to go.  Thursday at 5:30 ill be done then its  :D
heh, [high] school.
Write two debate cases(7 min and 3 min), arguruement blocks(about a page of philsophy), Make a resume portfolio(any idea how hard it is when your 17 and have had two jobs???)
yeah, yeah, I know, I got it easy
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
