Front Suspension question(s)
grogman45459
With 133K on my '01 YXL 1500 front(all original) end, can someone give me an idea of what I should be looking to swap out(and what to replace with) and what it would cost?
When driving straight down the road at any speed, a sound will start up on the drivers side that sounds like sand and gravel swirling around in the bottom of a metal garbage can. It comes and gos. Last night i jacked up the front end and with my hands at 9 and 3 I could teeter both wheels back and fourth, so some good slop on both sides there. Tie rods, ball joints, shocks? Everything?
Thanks!
The way you described that sound tells me hub bearings. The sound will be louder turning one direction at speed ( such as a sweeping turn on a rural highway ), then quiet the other direction. Replace both, if that's what it is.
They're between $150 -$200 at autoparts chain stores.
Timken has been a solid brand for years now, however nowadays it seems nothing lasts anymore. But so far, the 2 Timkens I installed in a customer's 99 Blazer last March are still holding up.
Thanks - so with a little help(ok it was alot of help!) from a friend, we replaced both front hubs, both inner tie rods and the pitman arm. Gave her an alignment and all is good, quiet, and tight again for now.
Good deal! :cheers:
Someday I'll gather up the motivation to replace the lower ball joints on my 51k mile '07 .... :)
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 623 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
