All Terrain Wheel and AT3 Pics
Ryan00TJ
Got the 275/65/18 AT3's mounted up on the All Terrain wheels. I love the look of the AT wheels on the red trucks.
New tire size 32x11" fits perfect stock height, no rubbing under any suspension compression. The reviews of the Cooper AT3's are spot on, a very nice tire. Ride is great, quiet and awesome traction. Very pleased with them!
looks good :thumbs: I just changed to cooper discoverer ATP's in a 265/70/18 and they are exactly how you stated the AT3's are. This is the 7th set of coopers I have had from street, performance, AT and MT. Cooper's are awesome! Can't beat the mileage warranty or price :smash:
Ryan, those tires look really good! :thumbs: Did you go with the P-rated version, 6-ply LT's, or 10-ply LT's? Cooper makes all three in that size, so I was just curious.
And Josh....I'm anxious to see those tires on your truck. I found them on Discount Tire's website, but can't find any details on the Cooper website. What's the deal? :dunno:
The details unfortunately are not on Cooper's site. However, you can call the number on their site and get all of the details you like, or call a Discount Tire.
Cooper actually makes the ATP exclusively for Discount Tire. I like the looks of them, they look a lot like the zeon ltz's. I will get a pic sometime today and post.
Thanks guys. Finally got the truck looking the way I wanted. I went with the P rated ones as I did not want or need a 10ply and the 4ply according to Cooper has a higher load rating than the 6ply tire. The P rated 275's are a 116T 2756lb vs 113S 2535lb for the 6ply.
The 6 ply does have a 16/32" vs 13/32" tread depth though. I decided on the P metric's as I only tow my 5Klbs boat and haul an occasional ton of gravel or firewood and I wanted to keep weight down going with the larger tire size.
BTW I had Justin @ Blackbear retune my ECM for the larger tire size. Awesome turnaround time, shipped it off the 31st and it was back to me the 6th of Jan. Noticeable difference and the speedo is dead on per my GPS. I have not run it enough to get a spot on estimate of the mileage hit yet, but it looks to be around 1 to 1.5mpg loss vs the 245/70/17's.
Good look'n truck man!! Glad you posted this. I've been look'n at these, I want e'm now that i know how they look. How do they ride?
Here you go! I went back to 4 ply from my 10 ply Falken's I had to get my mileage back. Still 33" tho :thumbs: Nice, quiet ride, and had a chance to try them out this morning on a new jobsite in some thick nasty mud and I was very impressed! Sorry for the dirty truck and crappy quality of the pics
Thanks for posting Josh! I like the look of those...kind of a cross between the Cooper Zeon LTZ and a Hankook Dynapro ATM. If I keep my truck long enough for the BFG's to wear out, I may look into these! Me likey!
Bought the wheels off Ebay for $725 shipped. They are as new condition. As for the ride, I like it.. The P rated tires absorb more of the shock associated with bad roads and holes more than my previous LT C rated 17" tires.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
