2012 Navigation Upgrade
Trav_13
Hey Guys,
Has anyone attempted to upgrade their 07-11 GM Truck and install the 2012 GM Hard Drive Navigation Unit? I have my 2011 Sierra Denali and would really like to learn more, or possibly pursue this upgrade to receive the added features of this unit.
My 2011 Sierra Denali appears to have different plugs on the back of the radio, compared to the new 2012 units. I am assuming maybe there is a different audio harness which ties into the actual dash harness, as all the other electronics in the dash appears to be the same, except for the radio.
I'm all ears, and wouldn't mind learning about what it takes to make this happen!
Does anyone have any input??
have you looked at the Advent OGM1 yet? search it on here ;)
from my understanding, the OEM nav will go in as long as you have Bose, but it requires a reprogram from a dealership. if you do not have Bose, then you have to purchase a GM Lockpick
Any specs on the 2012 units other than it is now a hard drive in it? Looks like the Chevy Cruze got an updated Nav system and a pretty big price cut too for that feature.
Thanks for the suggestion, I don't want to do anything but OEM though, I have heard of that Advent, however I want everything to work seemlessly and I've heard that some guys are having a few very minor bugs with the Advent...
I have had NAV in my 07 and 09 Trucks, and really like the OEM Radio, however I haven't upgraded my 11' SD yet, and just happened to notice that this new 2012 unit is different so I figured that might be neat and try to upgrade to that unit..
I don't think there is much more to it except its just something different looking...the background display is different as well.
  • 4 months later...
I have done it to my 2012 and I got mine from Greg at CPS Audio Video in California for 1550.00. It comes with the adapter harness, gps antenna, usb harness (for some reason GM changed the style of plug on the radio) and I opted for a video harness for an extra 50.00. And also keep in mind that it also has an XM tuner built into it as well.
Did the same thing from CPS ,works flawless !
  • 3 weeks later...
Id like to do this to my 2008 Yukon...
Is there a CPS website?
They don't have a web site you have to call them at 707-588-9300 and ask for Greg, he then will go through it all with you to get it setup. He can also add features like input's and output's for DVD monitors ect as well, just have to tell him before he programs the unit. That video harness is an extra 50.00 which is why mine was 1550.00.
Awesome...does your live traffic and weather work on yours as well?
i have an 08, so im guessing its not completely a direct swap...wonder where i can get the harnesses to get it working...
Greg at CPS provides all the nessesary harnesses and adaptors to get the unit hooked up.
Nope the radio is already programmed, you have to supply the vin to Greg, so when you get the radio all you have to do is remove the old radio, hook up the adaptors for the radio harness, install the GPS antenna Greg supplies, the XM antenna adaptor as the 2012 nav unit has it's own tuner built in, the harness to the onstar unit, and the radio antenna adaptor and usb cable and your set, no need for a trip to the dealer.
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
