Front End Alignment Question
Hey, if anyone out there has the current '03 front end alignment specs for the '03 half-ton 4x4 rado/sierra, I'd be very grateful.
Just trying to verify whether dealer is feeding a line of BS.
Thank you.
Document ID # 931741
2003 Chevrolet Chevy K Silverado - 4WD
Wheel Alignment Specifications
Truck Line
Model
Caster L-R
Cross Caster, L-R
Camber
Cross Camber, L-R
Toe
Steering Wheel Angle
Important
Caster is relative to frame. The caster values must be compensated for the measured frame angle. Frame angle is positive when higher in the rear and negative when lower in the rear. Refer to Front Caster and Camber Adjustment .
C15
Silverado, Sierra
Reg or Ext Cab
3.50 ± 1.00
4.00 ± 1.00
- 0.50 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
Silverado, Sierra
Crew Cab
4.50 ± 1.00
4.75 ± 1.00
- 0.25 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
K15
Silverado, Sierra
Reg or Ext Cab
3.50 ± 1.00
4.50 ± 1.00
-1.00 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
Silverado, Sierra
Crew Cab
4.25 ± 1.00
4.75 ± 1.00
-0.50 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
K 15
Silverado
SS
4.10 ± 1.00
5.10 ± 1.00
-0.50 ± 0.50
+0.10 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
C25LD
Silverado, Sierra
Reg or Ext Cab
4.50 ± 1.00
4.75 ± 1.00
-0.25 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
K25LD
Silverado, Sierra
Reg or Ext Cab
4.25 ± 1.00
4.75 ± 1.00
- 0.50 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
C25HD
Silverado, Sierra
Reg, Ext Cab or Crew Cab
4.25 ± 1.00
4.75 ± 1.00
- 0.50 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
K25HD
Silverado, Sierra
4.00 ± 1.00
4.75 ± 1.00
- 0.75 ± 0.50
+0.25 ± 0.50
0.00 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
C35/36
Silverado, Sierra
4.25 ± 1.00
4.75 +/- 1.00
-0.50 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
K35/36
Silverado, Sierra
4.00 ± 1.00
4.75 ± 1.00
- 0.75 ± 0.50
+0.25 ± 0.50
0.00 ± 0.50
+0.10 ± 0.20
- 1.0 ± 3.5
C/K 15
Silverado, Sierra with Rear Wheel Steering -- Values are for the rear of the vehicle.
-0.50 ± 0.50
0.00 ± 0.20
- 1.0 ± 3.5
© Copyright General Motors Corporation. All Rights Reserved.
Thanks a bunch, asepgrad98!  :thumb:
Actually, my dealer was right on w/ the spec.  Said the right caster was supposed to be +4.5 deg. vs +3.5 for left side to "compensate" for road crown, assuming you drive more often on the right of the crown (reasonable assumption).
Of course now, it won't track straight on a flat surface, but it's not off by much.  Guess it's not an issue really.
Thanks again.  :wtf:
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
