interior seat question?
are the seats pads on the Sierra and Silverado the same on the NBS? Looking at some Katzkin leather seat covers and there listed for Silverado, but will they fit my Sierra?
Yes,I have had a Silverado and a sierra,seats are exactly the same.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
