8.1 stalling problem when pulling out from stop
I have an 08 c5500 with an 8.1 Gas engine. When the truck is cold it runs fine but once it warms up when you take off from a stop the truck stalls. If you crank it, it will start right back up and be ok for a few min but then if you slow down and take off again it will stall. It does it when towing a load or empty.
It has not caused a check engine light to come on. Scanned it but there are no hidden codes either.
We have put in a new fuel filter which did not help.
We put in a new crank position sensor but still have the same problem.
Any help is much appreciated !!
I am pretty sure the 8.1 L had aproblem with their crank position sensor going bad and causing the problem you discribe.
  • 1 month later...
Early 8.1L had trouble with the crank sensor. 2008 might have a bad one but not common.
I would go with the fuel filter, because it should clog up twice as fast as most rigs because of huge amount of fuel that has gone through it..
