Cam swap wanted LS6 possibly?
would the LS6 cam be a good fit in my 4.8 or should i look at something else?
I saw a couple of ppl get about 35hp from that swap,BE sure to get comp cams pushrods though the stock ones bend easy.That cam should wake up that 4.8L,i would aslo consider new valve springs.
the cam will work just fine, but most people running it in a 4.8L love it for turbo applications.
are you looking for high end horsepower or low down torque?
I ran a 2002 LS6 cam in my 02 LS1 Camaro SS for a few months. With stock 241 heads, LT headers, Intake, exhaust, ASP pulley, ported TB, and tuned it made 376rwhp @ 361rwtq @ 6500rpms. Overlayed against the stock LS1 cam dyno graph the LS6 cam made no additional power until 3500rpms and did not come on strong until 4500rpms where the LS6 cam began to really pull away. Made 34 more rwhp @ 6500rpms and 12rwtq @ 4400rpms. It's top end cam for sure. The forced induction guys love it as it's an excellent blower cam. I would steer far away if you are looking for lowend power.
in my 5.3 i put a comp XR259HR (206/212 .515/.522 112 LSA) its got really great low and mid range torque and the top end is still better than factory. When I bought it I figured it was smarter to have the power where I use it the most. I gained a solid 2 mpg on the highway with it.
I believe all ls6 cams from 02-04 have the same profile. The engines were all rated 405hp. 01 was 385hp with a slightly smaller cam.
Mark
2001 LS6Camshaft
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
    ottogriffin
    ottogriffin
  • Who's Online   4 Members, 0 Anonymous, 665 Guests (See full list)
