2007 Silverado Changing Diff Gears from 3.73 to 3.42
Like everybody else said, not worth the time or money. Gains, if any, will be minimal. It would take quite a few miles just to break even after the swap. If you want MPGs, get a tune. 3.73s with the 4L60E are a pretty good combo.
With the 20" rims, keep the current gears. Depending on the truck's mileage, make sure you have a good tuneup (wires, plugs, O2 sensor). You will be fine otherwise.
Driving habits and a good set of tires will be more cost effective than swapping out rear-ends. When I switched from the factory Goodyears to the Bridgestone Revo's, I took an immediate 1MPG hit.
I would shop for a good set of all seasons, more street tire than off road, if that makes sense. The lighter the tire and rims and lower roll resistance, the better MPG.
As stated above, keep the MAF sensor clean, and change out the upstream O2 sensors and that will help as well.
The cost to make the change in both axles will run you between $1000 to &1500, and triple that if you have the dealer do it.
I am not going to do it here, but I ran the math for a friend of mine who wanted to go from 3.73 to 3.42 last month. It would have taken him, at todays gas prices, over 100,000 miles to recoup the costs in saved gas.
if you really want to do this, find someone who wants to go the other way, and just swap complete axle assemblies.
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 799 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
