XD series wheels
moose288
the wheels have less than 50 miles on them, not a scratch on em 18x9 +30 offset .. i decided to go with 20s reason forsale, lug nuts and tpms valve stems are included(not sensors)..fell free to call or text me with any questions
thanks ,jeff
800.00 tyd
865-850-5127
700.00 local pick up price
located in east tennessee
