what can cause an intermittent rough idle?
for the last week i have had an on and off rough idle. i put some seafoam in the tank and filled up with good gas in case it was some bad gas but it still comes and goes a bit.
What truck do you have? Sometimes, a rough idle is normal. How much is the tach jumping?Seafoam is a good start, but have you changed the plugs, cleaned the air filter, what octane of gas are you using?
yup 5.3 afm on a gmt900 85k miles and the tach jumps abut 150 -200 rpms when it does it. run regular 87 gas.
GM will tell you that it is normal. My 2010 idle is a little shaky sometimes, guess I just got used to it being that way. They all seem to do it for some reason.
A dirty throttle body or throttle body blade will cause a bad idle, also a dirty MAF sensor will cause a rough idle.
ok CEL came on today and i read the code, turned out to be a misfire in cyl 1 so i pulled the plug and it looked like it was in the ocean for 10 years. looked like lime scale build up. changed the plugs, all is perfect now.
Mine does that too :/ I'm at like 89k miles
