When you type your VIN in on the VCI page, is the list of stuff that comes up things that were already done or things that need to be done?  I bought my truck used so I don't know if the previous owner had the updates done.  I have to take my truck in to the dealer to get the seatbelts replaced due to a recall.  I was just wondering if I should have them update the computer while it's in.  Or, should I just leave things they way they are.  The trucks runs and drives great now.
The information that you see at the VCI page is updates and information that is available for your particular vehicle. It does NOT represent what has or needs to be done.
It is just information that is available for your VIN number.
Your dealer can tell what updates you have had or need by downloading the current flash from your vehicle computer.
Tom
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
