2001 Suburban w/ 5.3....I replaced the fuel pump a few months back, just the pump not the complete module. I bought the pump in an ACDelco box off Ebay and the part # comes up as a ACDelco-Mexico part # BGV00250
Recently the Sub has been hard starting after sitting for a while. I put a pressure gauge on the schraeder valve and my fuel pressure is low....like 40 psi. At least once on a cold crank, key on, engine off it only primed(~2 sec) to 30 psi. It always starts but generally not without a long crank or cycling the key on-off-on-off-on which is giving me a longer prime.
I didn't replace the regulator when the new fuel pump went in. I'm trying to avoid just throwing parts at this problem and looking for a little help which way to go.
I have little faith in the Ebay pump now but I'm not sure that is the problem. The problem could just as easily be the regulator. Is there a way to discern what is causing the low pressure....regulator or pump?
Thank you in advance.
Pull the vacuum line at the FPR, if you have fuel there, replace the regulator. You may also have a fuel check valve bad
Checked your fuel filter?
Edited by txab
I had a similar issue with my 02 Silverado 1500 5.3. The truck wouldn't turn over the first time I cranked it. I'd have to turn the key allowing the fuel pump to operate, then turn it back off, then on again like you're doing. It eventually got worse and worse. I replaced the FPR with no change in the problem. I then had my fuel pump and fuel filter replaced. The problem improved by having this done, but was never completely solved. Up until I got rid of it, I would start it like a diesel. Turn the key to on, pause, then crank it. If I turned the key too quickly it would be a hard start. Or if I turned the key to on and left it there for too long, I'd have to turn it back off before cranking it or the truck wouldn't start.
I also eventually had a section of fuel line replaced secondary to corrosion. That didn't improve the problem either.
Sorry I'm not much help, but I wanted to let you know you aren't alone. It always drove me nuts too because I never figured out the problem. I solved it by buying a new truck. Time will tell if that was a good fix!
I'll check the FPR tomorrow. Thanks for that easy check. Fuel check valve....where is it located? Fuel filter was new when the pump went in about 6 months ago. I know it could be plugged already....only way to check that is replace it. Might be an easy....what if.....
Thanks again for the suggestions.
I just had a similar problem. Replaced fuel filter, plugs and wires, with no change. Per the dealer, the check valve was bad, which made sense with what I was seeing in fuel pressure readings: initial key on gave zero pressure or full (~ 50 psi) pressure but quickly dropping afterwards. FPR was still good. Replaced fuel pump module (which I assume includes valve) and truck starts fine.
I agree on FPR check - pull the vacuum hose and look for fuel.
On 3/16/2012 at 12:26 AM, Mattt said:
On 3/15/2012 at 9:47 PM, txab said:
Pull the vacuum line at the FPR, if you have fuel there, replace the regulator. You may also have a fuel check valve bad Checked your fuel filter?
Quote
I'll check the FPR tomorrow. Thanks for that easy check. Fuel check valve....where is it located? Fuel filter was new when the pump went in about 6 months ago. I know it could be plugged already....only way to check that is replace it. Might be an easy....what if..... Thanks again for the suggestions.
Check valve is part of the fuel pump assembly in the tank. That's why it's best to replace the complete unit when you have a pump problem
Edited by txab
  • 2 years later...
Is it possible that my fuel pressure regulator is bad even though i'm not seeing any gas when i pull the vacuum line there? My 2000 yukon with 330k miles recently started having a long crank issue. It sometimes takes 1-2 seconds, sometimes longer before it starts. Previously, it has always started really quickly (much faster compared to my wife's 2007 accord, which I always think cranks a long time when I start it by comparison to my yukon). I recently changed plugs, wires, engine air filter, fuel filter and cleaned throttle body and MAF sensor. None of that has helped. I'm on the second fuel pump (it now has about 120k miles on it in about 4 years), so maybe it's the pump going again? But, I'm wondering if it might be the fuel pressure regulator, even though I'm not seeing gas in the line. I'd rather replace the FPR for $80 than the fuel pump for $600. What do you guys think - could it be the FPR? It idles, accelerates and runs like normal once started.
  • 6 months later...
This is a more closley related string so I'm reposting here.
19 Aug 15,
2000 Chevy Silverado Ext. Cab1500, 5.3ltr, automatic trans, 2 wheel drive, with 85000 miles on it.
I have a similar problem. A few years ago I replaced the fuel pressure regulator on the fuel injector rail and the problem went away. It started up again a couple weeks ago and the symptoms were exactly the same as last time. I live in Arizona and I don't drive this vehicle very much,- I'm retired - and it's possible that the diaphram in the regulator dried out and was causing the problem.
So I replaced it with a brand new regulator ($45.00) and it started up a bit better than before I replaced the regulator.
I drove it today and had a hard time starting the engine. I know that the fuel pump is working because I can hear it working for a couple of seconds after I first turn the key to "On".
I got the engine to start and had to "Goose" it just a bit to get it to smooth out. As I drove it, I noticed that the engine hesitated a little from a stop and even when driving at a slow speed. If I was doing about 30 mph and accelerated, it sped up just fine. No hesitation that I could notice.
I parked the truck and returned about an hour later and had a hard time starting the engine again. I had the same hesitation situation while driving home. When I got it back in the garage, I turned the engine off and tried to restart it. It fired up in a heartbeat. I tried it a couple more times and got the same good results.
One other odd thing: My fuel gauge began fluctuating just a little when this all began. It bounces between 1/2 and 3/4 tank while the truck is just sitting still. So it's not the fuel sloshing around inside the tank.
I don't have any other draws on the electrical system such as directionals or 4 way hazard lights flashing that might cause the electric to fluctuate.
I'm going to hook up my OBD II to see if there are any trouble codes but in the mean time, has anyone had a similar problem?
How did you fix it?
Thanks,
Keats, Arizona :help:
  • 5 years later...
Sticky starter or extended crank. Can this be fuel regulator bad when after Tahoe has been driving a lil to warm up then turn off for 20min then when you turn key to start it the starter will stay engaged for a second on its own. A couple more attempts then starts. Plz help
Starter staying engaged for second when you try to warm start. What makes that starter stay engaged? Kinda like it lost its fuel prime. It only does this on warm start. Cold starts in morning starts right up.
I have 2001 g m c Sierra 4.8 going down the road the motor surges what would cause this got new plugs new coils new wires and code comes up has a misfire
    jaszr2
    jaszr2
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
