33x12.5r20???? Help
Chisam117
Op, keep in mind that the stock 17's are only 7" wide as compared to your 20's, which are 8.5" wide. The coopers run small too. Good luck.
Yea those coopers are pretty slick I'm lookin at those right now. Im wanting the toyo mts but can't really make up my mind.
I got a good deal on my coopers by having discounttiredirect.com price match rims4less.com. rims4less is no longer in business and I think their prices are from a while ago but there website is still up and will go through the checkout so you get a total price. I tried to have treadepot.com price match but they wouldn't and told me that site is no longer in business.
Had to turn around on some back roads today so I had my truck off center and heard something rub while I was backing up. Got home and could tell where my tires were rubbing on my sway bar. Not bad but wanted to give an update.
Thanks for the update man. I think I'm gonna go with the Cooper tires also. I expect them to rub at times but jus normal driving is what my main concern was. Your not gonna cut anything are ya??
No I'm still going to say under normal driving conditions I'm not going to have any problem. See if you can get discount tire direct to price match that site I stated above. You'll save a good bit.
same dilemma I am going through.
I am going to keep my factory 20s and run the cooper STTs 33x12.5/20 or Nitto trail grappler MT 295/55/20....
I'm torn which way to go. My brother in law has had the coopers on his ram for 40k miles and they look good, fairly loud....but then again I've never heard the trail grapplers on the road...and I do a bit of highway driving so road noise is key for me.
Hows the road noise?
I can't speak for the trails but I think your going to have road noise associated with any aggressive looking tire. I would say from my experience the cooper is not an excessively loud tire.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
