Transmission Cooler
Has anyone installed an external trans cooler? If so what type did you go with? I have a 2007 2500 HD it has the 6.0 liter with a 6L-90 in it. I just put a brand new trans in it from GM, the old one had some issues, so I just went with a brand new one. When towing the trans temp really runs up there, around (200-210). I did have a 32ft Goosneck camper and a 22 foot boat behind that so, it is a load, which then in turns cause the engine temp to raise as well, any advice would be benifical. Thanks
you can use to tru cool 40k a lot of guys run this cooler and it usally keeps it about 20 to 30 degrees cooler than the stock unit
My trans on my 1500 runs at 190 degrees driving around normally not towing anything. When I'm pulling anything, its always around the 210-220 range. I have the tow package and transcooler.......so I figured it was normal to operate there.....
when towing or sometimes in town on hot days i get right around 200 also. I do think this is normal.
i have the B&M P/N:70268 13,000 BTU cooler. Its 11"x7.5"x.75" and on a 100 degree day my trans stays at about 175 degrees. $55.95 from Amazon.com
sorry if the quality id off, they are phone pics from when i installed
