Oil consumption help...
I've spent the better part of this morning searching forums trying to ascertain information for this oil consumption problem and so far haven't been able to find anything that's answered my question. This is the AFM Flex-Fuel 5.3, of course.
My truck is an LMG equipped 2WD Silverado, built in the US at Fort Wayne, with 8,100 miles. I have a friend who has a 4WD LC9 equipped Sierra, built in Mexico, with 21,000 miles. He recently discovered that his truck is starting to use oil. With that said, here's what I'm interested in finding out...
From what I've seen, LC9's are 4WD-only engines, but LMG's can be found in both driveline configurations. I've also observed that most postings about this issue have been mostly isolated to 4WD trucks, but there's no solid evidence I've found so far to prove this theory. Maybe it only affect 4WD trucks, or maybe just the people that are posting about the problem happen to own a 4WD. I'd be interested to see the statistics on this particular question. So what say you, LMG or LC9 in your truck? What's been your experience with them concerning oil consumption? Any 2WD folks having the problem too?
Just so I don't look like an idiot to anyone, I did read through the entire thread while I was researching this morning. There was too much inconclusive data within it to really answer what I'm looking for. I've looked at other forums and have googled the crap out of this problem and haven't found anything worthwhile to help me. It kinda sucks, but oh well. I'll keep looking.
Thanks for the help Ryan, it is appreciated!
The engines I believe are all built in one plant. Romulous NY comes to mind but I could be off base.
I think they're built in St. Catharines, Ontario also from what I saw on Wiki. Don't know about the Silao claim; I can't find anything to back it up. Doesn't really matter I don't guess, I was just wanting to know because it peaks my curiosity. 8100 miles on mine; 4000 on the current oil change and it's halfway between the 3rd and 4th dots so I think, for now anyway, I'm OK. :) Hopefully it stays that way but I'm still thinking about getting AFM turned off... there is a guy in my area that is LLC'ed to do tunes for GMs and not void the warranty.
Actually I lied about that. Word of mouth vs talking one on one teaches you things! Turns out what he does CAN void the warranty, but only if GM wants to. So far, the few folks that have had something go wrong while their truck was tuned did not get denied a warranty claim. With that said, I'm doing it. Getting rid of AFM, torque management, and a few other things. Never thought I'd do a tune but it is hard to resist now.
Romulus is in Michigan.
Its says right on the lower right hand corner of the window sticker what country the engine was made in.
According to GM Powertrain website
LC9 & LMG built in Romulus Mi and St. Catherines, Ontario. Nothing about Mexico
L9H, LZ1, L94 in Romulus Michigan and Silao Mexico
L96, LC8 built at all 3 locations
Maybe more people own 4wd so you hear about them more. IDK? I have 4wd and almost 10k miles and it doesn't burn/loose oil and it's the 5.3 with AFM. You tell me how to tell if I have a LMG or LC9 and I'll post it up.
Look for the RPO in the glovebox :)
I have the LC9 on my 11 Crew 4x4. Almost 16K on the clock....knock on wood no problem with consumption yet.
LC9 & L9H (6.2L) are aluminum blocks with alumimnum heads
LMG is cast iron block with aluminum heads
The LC9 is lighter in weight which means better fuel economy for the vehicle is used in.
OK, checked the glove box for my RPO code and I got the LC9, 2010 4x4 5.3 with AFM. Again, all good here and knocking on wood like greywolf11.
Just drive it and not worry. I traded off (moved up to a Denali) my 2010 Sierra LC9 with 30,000+ miles on it and it never so much as used a drop of oil. Just make sure to use high quality synthetic oil.
I seen a piston (only 1 was bad) that came from on of these oil burning engines ('07 GMC CC) and the rings were cooked right onto the piston, it looked one piece. The service manager (know him well) said the owner changed his oil every 3,000 miles at the local quick lube.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 937 Guests (See full list)
