Removing GMC Sierra Grill
Can someone do a write up on how to remove my 2006 gmc sierras grill, i plan on colormatching the chrome and would like the easiest way to remove and reinstall it. thanks.
if it's anything like mine, just squeeze the tabs with pliers and remove 2 or 3 bolts on top. Very simple.
Yeah the grill in mine comes out no problem, If the same, as mentioned above, the clips pull out from the strip that separates the upper headlight and lower housing. The rest have some bolts. Easy to get off. Most of the time lol.
What type of big plans? Unless you're talking about the whole color match thing.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
