airbag light
dalessierra
i have a 2004 seirra and the service airbag light came on so we hook a scanner up to it a the b0103 code right front impact sensor so replace and that didnt fix it so we replaced the sdm and had it reset at the gm dealership and the light its still chased all the wires and they are good i dont no what else to do please help
