2011 silverado leveling kit opinions
wanting to put a 2.5" leveling kit and maybe a small body lift on my 2011 silverado i want to run 33s with 20x9 or 18x9 fuels but not sure on the offsets looking for good brands and opioins so i do it right dont want to rub and want the right look and stance
thanks shane
No need for the same topic in multiple locations. Please see the chassis - suspension forum.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
