Frount bumper to low
I use my 2008 VMAX 4X4 1500 in the woods 8 months out of the year. But with the fog lights and the plastic spoiler its just to low. Two days ago I tore it compleatly off while driving down a woods road. I just thought I would ask others what they have done to get more ground clearence from their GMC.
Sounds like its time for a new bumper and a body lift
Sent from my ADR6400L using Tapatalk 2
Its just the lower plastic part of the bumper that got tore off. Its hooked to the steel with plastic rivots so it can be easily repaired. I was hoping there would be some kind of filler kit I could buy that replaces it and does not hang down so low.
Not sure about a filler, if thats all you nees to clear, if you dont have a level kit that could net you 2 in of height in the front to help tho
I second the 2" leveling kit. This will help you out alot. You can get a Rough Country leveling kit for about $70 plus the cost of an alignment. I have always had a RC kit and never had any problems at all.
I removed the lower lip under my bumper, then used a Zone 2" front level kit plus 2" extra blocks in the rear to lift the entire truck 2". FYI: my truck sat with the front too high with just the "level" kit.
I may keep an eye on rear blocks for mine. mines pretty close all around, but the front is oh so slightly higher for some reason. Even just an inch higher I'd be happy with in the rear.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,262 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
