GreenRado Birthday!
DamianSolomon
HAPPY BIRTHDAY GreenRado!
(I saw a birthday thread for BlueRado, but the calendar says its GreenRado's B-day!)
Are you guys twins or something and have different color trucks, or did I read the calendar incorrectly? :cheers:   :D  :)  :uhoh:  :thumb:  :P  :smash:
same guy.  He traded his 99 green rado for an 03 blue rado  :cheers:
Are you guys twins or something and have different color trucks, or did I read the calendar incorrectly? :cheers:   :D  :)  :cheers:  :thumb:  :crazy:  :)
Thanks for the thought!!  :chevy:
    zibzer2
    zibzer2
  • Who's Online   6 Members, 0 Anonymous, 806 Guests (See full list)
