steering problems
On my way home from school, the wheel started to seem tougher to control, so I let go of the wheel and the truck went sharply left. I pulled over to check it out: tire are good, all rods look good, and one boot looks to be going soon. nothing that would cause this sudden mal-alignment?
Normal use dosen't case something like this in one day, the wheel now has to be turned about 15-25 degrees left and held there to keep it straight.
it had that "flat feel" when I would let of the gas, like it was flopping a bad tire.
Had a friend last week with that problem. He broke a bolt on his upper control arm.
New bolts were around 9 bucks from a fastener store and it took me about 20 minutes to put them on.
If the actual control arm is broke, it will cost a wee bit more to fix.
Just my .02
check the tire psi and cross rotate teh front tires to see if it starts pulling the otehr way, :cheers:
I agree.  Tire may have broken a belt.  Had this happen twice on my furd ranger with the same set of firestone firehawks ss tires.  Had the tires rotated and didn't make it out of the parking lot it pulled so bad.  They rotated the front two and the pull went the other way.  After the second one went, I replaced all of them.  They still had plenty of tread and I kept the air pressure up.
okay this is wierd, it corrected it self within a few hours, drive almost perfectly straight now, and I know that it want the road I was on, cause I drive them everyday. OH WELL!!
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
