Newbie from Seattle
Regency
Hey guys new here pretty cool site can someone point me to the build threads? But I have a 2008 Gmc Yukon slt-2 "Regency" Edition. The current mods are 24" wheels, license plate Leds, Denali bumper, some aftermarket headlights, custom interior, cf trim, Rosen nav, esky mirrors, resonator delete and a new tip. So yeah that's me!
http://www.youtube.com/watch?v=n8E0z-Ih0qw
I've done the DL3 swap so if anyone needs any help just send me a pm
Here's the list
Build List 2008 Yukon Silver Birch Metallic
This * means paint to match
Exterior:
- GRILLCRAFT SW Series Polished SS Mesh Grille/ * Surround W/ CC Stamped*
- Denali Bumper Done
- Denali Roof Rack*
- Escalade 09+ Mirrors Done
- Debadge Everything Done
Interior:
- Fatmat Rattle Trap in all Doors Coming Soon
Performance:
- Volant Intake
- Straight Pipes
- Corvette Servo Done
Paint:
- Medium Tint Tailights and 3rd Brake Light
- Xm antenna*
Audio Video:
- Alpine MRP-M500 Coming Soon
- Headrest Monitors DONE
- Night Vision Back up Camera Coming Soon
- Jl Audio W6 10" Coming Soon
Wheels/Suspension:
- 2" Rear drop
- R1 Rotors (Front and Rear) w/ silver calipers
Lighting:
- Oem Painted to Match heads w/ 8k
- Fogs LED 8k* Coming in Spring
- Dl3 Puddle Led’s 8k Coming Very Soon
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
