GD Muffler for the 6.2L
I'm just replacing the muffler, and cutting off the resonator that's it. If I need 3.5" pipe that's what I will use. Def don't want to change anything for the worse.
Found the Spintech Muffler in 3 1/2". For those of you with louder exhaust do you hear the engine changing tune when the variable valve timing is working? Not sure if this would be annoying or not?
Not sure what you mean by changing tune with VVT, but the "burble' from 6th to 5th on the highway is better than any music I've ever heard- and I love music!
I was told by a guy at work that his trucks exhaust changes the tone whenever the vvt is working? Kind of like how it would with AFM just not as bad.
Ah..............I dunno, haven't noticed- I don't think VVT works that way. All I can say if you like a modern american muscle V8 corvette sound you'll love these things with an exhaust! I put a 3k stereo system in my truck and never use it- I like the sound of the truck better! Mine's not loud though, it's kind of like a tuned "burble".
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
