Truck Needs More Juice
Ordered my Stinger HPM 1/0 hyper twist cable. I ordered 5 feet of blue for the power and 10 feet of gray for ground. I'll have pics of the nice new Mac Daddy of an alternator and the wire when I get it. Hopefully I will get it all by Wednesday, I think the alternator will look good with the 3 piece VMax engine covers I have.
I'm thinking of running it through the power box near the alternator since I have something there already to get power. So alternator to power box to battery is what I'm thinking. Also where are the ground points I have to replace? I will be using Stinger gold plated 1/0 5/16" ring terminals.
  • Replies 72
The big 3 is the battery ground to chassis wire, the chassis to engine block wire, and the alternator plus to battery plus wire. Clean all surfaces off so its good bare metal and use coppercoat. I used 2/0 welding cable LOL. It was free.
Where are the chassis grounds? And the engine grounds?
Sent from my DROID RAZR using Xparent Red Tapatalk 2
I forget man, look for a bare braded ground off the block that straps to the frame it's usually just short. Yank it off and replace.
would I replace the battery ground or add in the 1/0
Either or, if you want the extra wire then go ahead..
Ok, do I run straight from battery to alternator, or hit the red junction box before the engine? I ordered extra ring terminals in case.
Theirs tons of info and videos on the big 3 upgrade. Google it, crutchfield actually has a good write up I think...
It seems easy to do. My wore and terminals come today. Alternator tomorrow or Thursday. There were just the little things I was curious about like adding the wires or replacing. And that little junction box threw me off.
Big 3 wire came in. Stinger HPM hyper twist 1/0. And Stinger 24k gold ring terminals
I'm seeing people online (YouTube, fullsizechevy.com) going Batt - to engine and Batt - to frame, is this right? Factory goes from Batt - to engine
Apparently I have to run to Home Depot. I dont have crimpers big enough
use a vise
Sent from my ADR6400L using Tapatalk 2
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   1 Member, 0 Anonymous, 587 Guests (See full list)
