New exhaust sound coming soon
New Spintech muffler should be at my door some time soon and I got the 3.5" dia. straight pipe ready to replace the rear resonator.
Hope it sounds as good as the clip on the you tube vid I've watched and listen to a few times.
My Spintech muffler came in today :) and I have the straight pipe for the resonator replacement already so I think I will take it to the shop this friday, BUT should I weld all the new joints or use band clamps?
I'd use quality band clamps
Sent from my PIECE OF CRAP DROID X2 using Xparent Red Tapatalk 2
  • 1 month later...
I'd get it welded but make sure you get someone that can actually mig weld worth a dam. I got my exhaust done by a shop and they did some horrible mig welding there was whiskers all over the place. And they used some sort of putty to seal it up so now I have 2 pretty bad exhaust leaks.
Sent from my smartass iPhone using Tapatalk
Did you ever get your exhaust on?
Unfourtuantly I haven't done yet and I keep trying to get to it.
I will be welding the pipes to the muffler while its on the work bench. Then using band clamps to install between the section I cut out. I'm off till Jan 2 so hopefully in that time frame.
Never heard of spintech, What does it compare to?
That's a good question, I'm not sure I found a clip on you tube and I went from there.
All I can say is it sounds amazing on the 6.2 in the video.
Sent from my BlackBerry 9300 using Tapatalk
I have had spin tech on my last 4 vehicles...price mufflers but you will love the sound. I could compare it to a flow master but better sounding.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 628 Guests (See full list)
