Had an allignment done today
Had an allingment done on my 97 k-1500 today
Cost me 69.95  It drives a lot better now also doesnt pull as much
100,054 miles
        Left Front                       |       Right Front
Camber - (before 0.5)(actual 1.2)|(before 0.6)(actual 0.6)
Caster - (before -1.8)(actual 2.8)|(before 3.1)(actual 3.5)
Toe - (before 3/8)(actual 1/16)   |(before 13/32)(actual 1/16)
                     Front
Cross Camber - (before -0.1)(actual 0.5)
Cross Caster -  (before -4.9)(actual -0.6)
Total Toe    -   (before 25/32)(actual 1/8)
Kinda whacked out IMO
Going to have to watch it on the potholes and washboards
:cheers:
