Bolt pattern and backspacing question
Have a 96 gmc sierra that i wouldnt mind putting some wheels on, what backspacing do you need and what is the bolt pattern? Also how wide do most people go on the the wheels, it is just stock ride height and will still be running a 265 tire. I know this has probably been asked a million times but i cant find the answer to this doing a search. Thanks
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
