exhaust manifold - found half a bolt on the driveway
Cat laws are annoying. The shop I contacted told me they won't change anything before the cats; won't install longtubes or even shorties. Everywhere I go there is some disclaimer in red ink that headers with or without cats are only for off-road use and cannot be used on public roads. Looks like self-installation is the only way, and even trying to do this only once (by using 304 stainless parts w/ lifetime warrant), I may still end up paying money down the road ... in fines.
Stupid bureaucrats. The law is so screwed up that states maintain exemption lists to protect the consumers (who are willing to buy working aftermarket cats) from laws made to crack down on cheap or phony parts made to cheat on emissions tests. If there is a special version of hell for bureaucrats, hopefully it has an impossibly long, contradictory set of requirements for making laws. Nah, they'd just let lobbyists talk them into writing themselves exemptions ...
I just had to have mine fixed. I paid an exhaust shop $400 to remove/replace the bolts on both sides, that also including drilling out the PIA driver side firewall bolt and one of the broken PS bolts . I supplied them with new dorman manifolds I bought from Rockauto. This is one of the few times I didn't mind paying someone to do something... my truck spent the 1st 4 years of it's life in Indy and I take it to western NY almost every winter. I don't think they had fun removing the exhaust bolts...
Thanks, that gives me an idea. Maybe I'll have them replace the bolts now, then I'll put long tubes on myself - should be easy to remove the new bolts. Dynatech's website had extensive directions for removing my factory Y and making room for installing the new parts. Time-consuming ... but apparently it can be done with hand tools and good clamps. Not sure if my EGR tube should be replaced; the tube appears melted and deformed, and both flanges (?) are rusty.
A local lube shop replaced the bolts and gaskets. The truck appears to run fine. Bill worked out to $330 so I guess they were lucky with the other bolts. If I put headers on soon, the bolts should be easy to work with.
Smoke testing revealed no vacuum leaks. Every seal on the intake tube is tight, very little movement. None of the plastic is deformed. MAF and fuel consumption readings display A/F ratios between 11-14 : 1, assuming I understand the units correctly. No idea why the lean codes appear but will data log again - a 30 minute trip with conservative driving and then again with aggressive driving - and ask BBP if they can tell anything from the logs.
So far I've only lost one bolt head, rear driver side. It's not giving me any grief so until then I'm leaving it alone. I'd be likely to cause more problems fixing it.
    tararebecca
    tararebecca
  • Who's Online   0 Members, 0 Anonymous, 563 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
