Sierra Silverado Audio Control Switch Upgrade DIC
Just ordered the Switch, Harness and DIC (Left Side) for my 2010 Sierra. Yes, should have bought it with the vehicle but am saving plenty by adding afterwards.
All Plug and Play. The switch has bluetooth on it but I am not ready to buy the ONSTAR Dongle Module yet as this will require the BCM reflashed. Yes GM frowns on this part but there is the odd tech that might help you out
Right Side Audio Switch with Bluetooth GM Part # 25851951
Harness behind horn pad/Airbag (Need Left side Cruize switch already on the wheel) GM Part # 25889498
DIC (Driver Information Center) GM Part # 19159438
A dremel will be needed to accomodate a bit of trimming to seat the harness
Hint, have a look on ebay for a bit of savings
