Mudflap reccomendation??
bdseagles93
First of all idk if this is the right place to post this but i need some help. I just put 2 inch wheel spacers on my 2010 silverado and my mudflaps look terrible from behind because they are so far inside. Does anybody have any ideas on any styles that i could buy that would help it look a lil bit better?
Yeah, take em off and let it get dirty. Its a truck for goodness sake. :lol:
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 290 Guests (See full list)
