Fuel Economy
Read post #22, it explains why it cannot stay in V4 mode for over 7 min.
I would re-read that post again. No where did it say that was the reason or emplied it.
But say for instance that is the case and you can only drive 7 minutes max in V4 mode. Who has ever drove longer than a minute in V4 mode before it switches to V8????? I know I haven't, prob lucky if I've ever hit 30 secs! My point was that while the truck is in V4 that you can program for a better AFR and possibly spark delivery etc to increase V4 power which enables it to stay longer. It can still switch at 7 minutes and switch back, but you effectively extended the operating range of V4.
  • Replies 50
A couple comments. GM does exactly what you're talking about. In v4 the spark map and fuel map are adjusted for that mode. The seven minute statement (which isn't a hard and fast number by the way. Different stock strategies vary that number quite a bit over the years) is to allow for thermal equalization across the cylinders and to help prevent oil aeration. The aberration was a bigger problem in the first generation AFM and there was actually a TSB I believe for adding oil shields in the valve covers.
Our module will keep it in v4 a lot longer than stock does without overriding any safety timeouts and while in v4 the AFR and spark are optimized.
Ok I'm pretty sure I see how you extended the operating range. Do you know the resolution of these sensors for the AFM by any chance??
Not sure I understand the question ... which sensors?
The stock ECU uses the standard sensors (MAP, TPS, O2 sensor, knock sensors, MAF, cat temp, speed, RPM, etc.) to input to the strategy calculations to come up with things like spark advance, load, fuel mass/cyl (and air mass/cyl), AFR (based on O2 periodicity), calc crank acceleration, and a HOST of other stuff to optimize fuel and spark delivery. There's really nothing unique to the stock AFM sensor-wise other than an indication of "ON/OFF" of the individual cylinder lifters/coil/injector. Those all have some diagnostic input so you can see if a solenoid failed (and in what manner it is "failed"). All the magic is in the ECU engine model in the strategy/OS.
This occurs dynamically regardless which mode the engine is in, although when it does switch mode there's also a change in strategy to optimize for the cylinders turning on and off. It's really cool to see it all work together ... some pretty awesome real-time physics! Our module does a strategy in a similar manner to interact with the AFM to alter the behavior .. it does NOT alter any sensor inputs.
I understand all of that, I was wondering if you knew the resoltion of the TPS and MAF sensors in particular. Resolution in bits specifically.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
