Fuel Economy
Is there anything you can do for the 6.0 that is non-AFM?
Sorry, this works in conjunction with the factory AFM hardware.
Sounds interesting ... is there any ill affects from it staying in 4cyl mode longer ?
Nope. We've ran a lot of real world miles and tested on Dyno for hours with no ill effects. In addition, all of the stock factory fail-safes and safety protocols remain in place.
  • Replies 50
Welcome! Sounds interesting. I often wondered if some programming could be done to change the AFM parameters.
The best programing to do is to "delete" it.
When I purchased my 2013 Yukon Denali (6.2L) the LAST thing on my mind was "fuel economy".
If you want "fuel economy", go out and purchase a "Toyota Scrotum" or some other piece of junk.
JMHO
But wouldn't this device also mean less power all the time as well?
I know most of us here have the pesky AFM tuned out and have seen better MPG's with it disabled.
Looks like AutoAnything lists the product at $199.99.
I was always told the reason it doesnt stay in 4 mode is due to cylinder heat and I believe the longest they have it programed for is 7 minutes I think if you can keep it in 4 mode that long under stock settings, it all has to do with cylinder expansion. I think keeping it in 4 mode longer then whats called for could mean ill effects in the long run on the motor due to uneven cylinder heating.
Nope. It is only active at low load conditions. Step into the throttle and it pops into v8.
We don't override the stock safety systems for these types of things. The key is that on the over all average we enable V4 a lot more. The thermal balancing still takes place (it only takes 30 seconds or so in v8 mode ).
We don't reprogram anything in the stock ECU. We are a stand alone controller that monitors ECT, engine load, throttle position, MAP, spark, etc. and the AFM hardware status and work with the stock strategy to extend the AFM operation.
So, If most of us doing regular driving and gettining 16-17 mpg, what can we expect to see if we install the Range?
On average, you will see between 7 and 10% gain. The determining factors will be your driving style and conditions. We had a limo driver company that was seeing 11-13% on two vehicles (stretched Suburbans with the 5.3). But they did a lot of low speed steady cruising (which is ideal). We did a LOT of Simulink on-vehicle modeling and chassis Dyno testing to verify things (with a five gas analyzer) before we turned it loose in the "wild" for real world results.
Check out http://www.rangetechnology.com and there's more data (especially look at FAQs and the Support Site link at the bottom of the pages).
Does it make any difference if the truck is tuned or not?
Does it very based on the fuel used at all? Will 87 run as good as 93, i heard if i ran 93 my truck would stay in v4 longer. Any truth to that?
Sent from my ADR6400L using Tapatalk 2
It shouldn't make any difference as long as the tune isn't over aggressive.
Actually there is some truth to that. One of the criteria to dropping out of v4 is detonation (which the Ecu will retard the timing for). Higher octane fuel allows for more timing under load without detonation and v4 mode is definitely very load sensitive.
If you ran 93 octane fuel and are NOT tuned for it, you will actually be wasting money. Without the proper timing advance 91-93 octane fuel will not help with performance. Read around the "Performance Engine Tuning" section, it's explained over there.
In general, thats true, especially in economics at the pump. In the context of the v4 stuff , the higher octane can help with keeping the timing up in v4, which helps with efficiency. Take a log with HPTuners or DashBoss and you can definitely see this all in real time.. If the fuel octane is too low for the load range, you'll get retarded timing and and it's especially sensitive in v4 mode. Altitude, alcohol content, air density, etc. can all affect where the timing map adaptation ends up. Problem with this is that higher octane = higher $ at the pump and the benefits may not offset the cost, especially in the small effect on v4 performance.
Being top teir gas around me is 3.08 reg and 3.48 Prem, to fill a 21 gallon tank would be an 8 dollar difference. I'll keep to my premium.
Drove my pile 760 miles last weekend hauling a trailer and 2 ATVs down the interstate(doing 75). Got a whopping 11 mpg there and back. I do have 275/70-18 E range BFGs though. I am not really complaining. Any extra mpg would be great though.
How fast did you go? If over 70 MPH, your mileage is normal. Remember, it is not always the total weight of the trailer that will kill your mileage, but air resistance. Was it windy that day? Some time ago I pulled an empty single axle U Haul open trailer with a raised near solid talgate, in strong winds. The tailgate acted as a sail and cut my mileage down to 12 MPG at 75 MPH.
I am not sure you are right. What you said is very true of old vehicles with distributor and fixed ignition timing. However, modern trucks like these have ignition timing advanced by the engine ECU and they have a knock sensor which enables more timing advance with higher octane gas. I would definitely recommend 93 octane for hauling or pulling heavy loads. I am not sure how much using higher octane helps for everyday driving when the truck is not loaded, but it is worth experimenting with to see if the mileage does not improve.
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • I agree, there is no one answer fits all as every rig is different, one may be pulling some little aluminum fishing boat while another is towing a monstrosity that weighs a lot and hopefully the owner if the rig has some prior experience to know what drive mode they should choose.    It also struck me and this is from watching a few of those boat ramp escapades videos in the past, Ford being one of the vehicles that has the auto front axle hubs and sure enough its found out that one hub has crapped out and won't engage and may not have manual hubs to even select on both sides so they are on the boat ramp stuck with no four wheel drive and spinning .... they flat out need a tow to get up the ramp and deal with the vehicles new found issues. That can happen to all brands of pickup, finding out either four wheel drive or 4 low isn't working right at the time its needed it to work as some electronic crap has failed.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
