07 Denali, bluetooth & nav problems
I bought a bluetooth vcim for my wifes 07 yukon denali and for my 08 2500 hd. Both have nav, the hd was added but is factory, and it works flawlessly. The yukon is giving me quite a bit of trouble though. After getting everything installed i couldnt get the truck to understand "bluetooth, bluetooth ready, pair", or anything relating to using the bluetooth. It kept saying voice command not recognized. Also it had the nav all screwed up, it gave me the red slash through the GPS icon and had me in Pennsylvania. Other than being in the wrong state, it still showed the vehicle moving in the right direction on the screen. What could be a problem here?
red slash means its not recieving the signal from the antenna so maybe check your connections on that , once the red slash is gone it should show you in the right place untill then it will be in the last spot it had a satalite fix .What year is the VCIM in the truck not reconizing the bluetooth commands ? my friends 2010 is differant than my 2009 ... mine I think without trying it I have to OnStar first wait till it says OnStar ready then Bluetooth
im not sure on the year, i put the old one back in and everything went back to normal. i talked to the guy i bought it from and he checked it in his yukon b4 i bought it and it worked. It has an old nav disc in it, could that be a problem?
not sure if it matters, but the nav disc is version 2.0 in the yukon and 4.1 in the hd. the vcim is out of a 2010 silverado that i got for the yukon
