Need some tire Info from the experts
Silvertipgrizz
I have a 2011 GMC Sierra w/the max trailer package, I'm currently running the stock 265/70R17 tires. I recently had a level kit installed and was looking at bigger tires. I was wanting to go to a 285/70R17 my question is am i going to cause problems with all the sensors going to a bigger tire?
Nope. Go for it.
The only thing you may have to deal with is your sensors not liking the ability to run a higher PSI in your new tires (if they're an LT tire) compared to your stock (p-rated) tires. If, for example, the max PSI on your old tires was 44, and you run 55 psi in your new tires when towing....your TPMS will think you have too much air in them. It's an easy fix though...just have the tire shop (if they can) or your dealer change the 'magic number' on your TPMS to a higher number, depending on the load rating of your new tires.
can have the speedo done from blackbear....and get a little more power / better shift points out too.
and i have 34" KM2's and been running them at about 55 PSI all the time (just found out that a year ago thats what the tire place put them to and i haven't touched them since) and i havent had any problems. No warning lights except for the one time i got a 3 1/2" screw in my tire and it went flat.
The sensors on that particular year model truck like mine only react to tire pressure that is significantly low. Even the manual won't say how low.A higher pressure will not cause any problems. I know this because I replaced my stockers right out of the box with BFG TA/KOs and run 45 psi all around. You can run them up as high as you want ,just not too low.
Well the max PSI on the stockers was 44, so it's probably ok with you running 45. However, I know first hand that some TPMS systems will trip the light if the pressure is too high. On my 2009 silverado, when I switched to 17" BFG's from my factory 20's (which were rated at 40 max, I believe) the tire shop put 65 PSI in the new tires....and it tripped the light. The service manager at my local dealer said that the system is set to look for a certain number...and too much variance from that number...either too high or too low...will set off the light. You probably just haven't had any problems because you're only running 1 PSI over the stock tires' rating.
The door specs on my 2012 rig calls for 32psi front and 38 psi rear cold.That's on the max trailer pack 4X4 Silverado. I've run them up to 52 psi searching for the right pressure setting for optimal tread contact unloaded. Not sure what overpressure window the preset would be looking for as 52 psi would have been exceeding the design run pressure on the stockers and initiated no light .I've never run them down in pressure to see where a low pressure situation would initiate the light. Of course I keep the DIC on tire pressure most of the time anyway.
Yeah, I'm not sure how low or how high the PSI needs to be to trip the light. On my 2009, with 285/70/17 BFG's, I had the 'magic number' set to 45 PSI, that way I could run 38-40 when empty, and bump up to 50-55 when towing...and the light never came on.
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
